Steering or suspension issue
Old Apr 28, 2016 | 12:41 PM
wingman7000's Avatar
wingman7000
Default Steering or suspension issue
Within the past couple of weeks I've noticed that a noise from the front driver's side when turning the wheel sharply to the right. I first noticed it backing out of my driveway and again in a parking space. It sounds like kind of like a grind and pop and I can feel in the steering wheel. I looked under the wheel well but I didn't see anything broken or loose. Again, it is only when its sharply turned to the right and backing up. Any ideas would be appreciated.
Old Apr 28, 2016 | 12:49 PM
dakotaff's Avatar
dakotaff
Probably a CV joint. Check around the boot for tears or grease leakage.
The grind, pop, or banging when turning is a symptom.
Old Apr 28, 2016 | 01:55 PM
wingman7000
That was one of the things that popped in my head (no pun intended) I will check that out. Thanks dakotaff!
