Odometer codes?
Old Dec 10, 2016 | 01:48 PM
rob98801's Avatar
rob98801
Default Odometer codes?
Having searched High then Low and again High I can find no write up on the odometer codes showing up on my 2007 Dodge Dakota 2wd 6 speed.
Using a code reader there are no codes stored but if I use the key and read for codes on the odometer I get the readings, .319, c542, 5722, hr4059.
Try as I may I can find no where on the web what these codes are.
Old Dec 11, 2016 | 01:02 PM
dakotaff's Avatar
dakotaff
Is the check engine light on? Or is there something displayed on the instrument cluster? Is the truck running bad?
We need to know why you're searching in the first place. But hr4059 is 'Hours Run', so that's not a code at all.
And how old is your battery, a weak battery will mess with all sorts of electronics on these trucks, a replacement or PCM reset may clear up any issues that you are having.
FYI:
Here is a one post from 2007 with the same codes as you see, but it's his only post, so no solution or explanation at all.
https://dodgeforum.com/forum/3rd-gen...ml#post1031343
Old Dec 11, 2016 | 02:19 PM
rob98801's Avatar
rob98801
Why? I think its my OCD!
There are no codes when using the OBD2, The battery is new within the last 6 months, The truck is running great. The Hours Run is what I Guessed but I can find no reference to it or the other codes on the internet.
So it just bugs me is the only reason I am looking for an answer.
Old Dec 11, 2016 | 04:29 PM
dakotaff's Avatar
dakotaff
Oh..., don't worry about a thing then, just drive it like you stole it!
Old Dec 11, 2016 | 06:13 PM
rob98801's Avatar
rob98801
BUT I'll know its there,
Old Dec 11, 2016 | 07:13 PM
Just think about puppies instead.
Old Dec 11, 2016 | 08:09 PM
rob98801's Avatar
rob98801
The solution to all problems......Just Think of puppies.
