Transmission Gasket Replacement Help
Old Dec 12, 2016 | 01:47 AM
FatalcasT Lee (Lee)'s Avatar
FatalcasT Lee (Lee)
Default Transmission Gasket Replacement Help
Needing to replace the gasket due to a leak. Main question is getting the pan bolts off the are directly above the crossmember the holds up the trany. It is such a small clearance that it is beyond my patience. Is there a trick or tip to get those out or is it just a grin an bear it thing.
Vehicle: 2005 Dodge Dakota SLT Quad Cab 4x4 545RFE tranny
Thanks for any help
Old Dec 12, 2016 | 09:24 PM
Jaded's Avatar
Jaded
Been a long time since I did mine, but seems like I had to take the crossmember out.
You can read some threads around here for help. Like this one.
https://dodgeforum.com/forum/3rd-gen...dy-do-one.html
Old Dec 18, 2016 | 12:01 AM
djsilverjohnson's Avatar
djsilverjohnson
When I've changed the fluid and filters, I just put a jackstand under the driveshaft and remove the crossmember and transmission mount.
Old Dec 19, 2016 | 05:53 PM
FatalcasT Lee (Lee)
Thanks for the help. Got it done with out removing the crossmember. Has anyone ever installed a drain plug in their pan?
