Ignition Key Cylinder replacement
Old Dec 30, 2016 | 05:41 PM
Manicmechanic's Avatar
Manicmechanic
Question Ignition Key Cylinder replacement
Does anyone know how to install a new factory key cylinder replacement (P/N 5018702AA) so I can keep the original key? I know how to install it in the column but how do i set the tumblers up to recognize my key? No instructions came with the new assembly. 2008 Dakota
Thanks
Old Dec 31, 2016 | 12:00 PM
Vladek's Avatar
Vladek
If it can be done, and that is a really big IF. You will more than likely have to go to a master lock smith.
Old Jan 1, 2017 | 11:04 AM
Manicmechanic
I was advised by the parts tech that it can be done, it just didn't come with any instructions and I can probably figure it out. I was just asking if anyone has already done it and can advise. The lock comes with tumblers I just need to know the procedure to set them.
Old Jan 1, 2017 | 12:14 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Take your old AND new cylinders to a locksmith and they can do it for you.
Old Feb 21, 2017 | 10:47 AM
wsmith5's Avatar
wsmith5
Default not hard
not hard to do just fidley basically replace the "tumbler keys" ( in the slots ) with the same number tumblers tha came with the new cylinder. see this video
Old Feb 23, 2017 | 10:02 AM
Manicmechanic
https://www.youtube.com/watch?v=yntb_qGNzEA
Great! finally a post with some real info, new it had to be possible and glad I waited. Thanks
