2005 Dodge Dakota wiper problem
Old Jan 3, 2017 | 02:13 PM
Bigal015's Avatar
Bigal015
Default 2005 Dodge Dakota wiper problem
Wipers only work in intermittent mode and won't change speed when turning switch faster settings. Swapped relay in Power Distribution Center 77 - I-Wipe Relay with 78 - Wiper - Hi/Lo Relay and have same problem. Both these relays seem to be the same.
Old Jan 3, 2017 | 03:39 PM
Moved to the correct section. Could be the switch.
Old Jan 4, 2017 | 12:22 PM
Bigal015's Avatar
Bigal015
Is there a way to test and see if the switch is functioning properly or not?
Old Jan 4, 2017 | 12:54 PM
northgator8's Avatar
northgator8
Search for Multi-Function Switch on the forum to see what can go wrong with these.
Turn signals generally take a dump first, then the high-low beam switch. But there is so much going on in there that anything can be the first to go.
What year is your truck? I think I have a couple for pre-2007 that I pulled at Kenny U-pull that I could make yours. (I'm in Ottawa too)
Had an '06 so I grabbed a couple, I now have an '08 so the switch is different.
Old May 31, 2018 | 10:40 AM
Bigal015's Avatar
Bigal015
Yeah it ended up being the turn signal switch. Got it replaced and everything works great now. Thanks all.
