looking for new shock/strut assembly. suggestions?
Old Jan 24, 2017 | 10:19 PM
Stronghand93's Avatar
Stronghand93
Default looking for new shock/strut assembly. suggestions?
Tax time coming up soon and going to replace most of suspension parts. Right now currently running most stock parts with a 3in spacer. Did not do my research before I bought and installed the spacers and learning its just tearing everything up slowly.. But what are some good options I should into.. Right now currently looking at a pro comp kit and a fox shock setup for rams that a guy told me that he installed with no problem on his dakota. Not that knowledgeable about suspension parts/ upgrades so all info would be greatly appreciated.. 2006 4.7 4x4
Old Jan 25, 2017 | 07:56 AM
Moog suspension parts. Monroe or Rancho struts. Not aware anyone has successfully installed Ram parts on a Dakota without a lot of work.
Old Jan 25, 2017 | 08:55 AM
dakotaff's Avatar
dakotaff
Yeah, Rancho & Monroe are the most popular replacement struts. And while you're working on the struts, I'd suggest getting a smaller leveling kit, max 2". Good luck fitting Ram parts on your Dakota, not sure I'd trust 'a guy'.
Old Jan 25, 2017 | 09:07 AM
Stronghand93
Was deffiently going with moog parts just confused on all the strut and shock stuff
Old Jan 25, 2017 | 12:21 PM
Not too confusing, you have 4 choices. OEM, KYB, Monroe and Rancho. KYB is the OEM replacement. Monroe is a bit firmer and Rancho is the firmest. There is no aftermarket "suspension lift" for these trucks. If you are 4x4, 2" coil spring spacers in the front, lift blocks or helper springs for the rear and a 3" body lift will get you roughly 5" of lift.
Old Jan 25, 2017 | 03:41 PM
rookie's Avatar
rookie
custom coilover
Old Jan 26, 2017 | 12:07 PM
superdak05's Avatar
superdak05
go with the Monroe quick strut replacement, well worth the money and less aggravation then changing out the entire strut just to replace and rebuild.
Old Jan 28, 2017 | 10:10 AM
Vladek's Avatar
Vladek
When i did mine last summer, I used moogg complete strut assembly. I only came across three problems. 1) couldn't use spring compressor, since there wasn't enough space between coils. I used rachet straps (a death trap). 2) was a major pain in butt with 2" spacer. 3) After getting everything together, the front wheels would have major vibration when fully extended (when driving down the country hwy, hitting the little bumps and turns.) Everything was in a major bind with the 2" blocks.
After removing the lifting blocks. everything is perfect. from instulation to driving. RockAuto is where i got everything from. upper and lower ball joints, sway bar parts, tie rod ends, hub bearings, cv shafts. I did everything at once to be done with it.
