Aftermarket Bluetooth 2007 Dakota
Old Feb 15, 2017 | 11:22 AM
doco's Avatar
doco
Default Aftermarket Bluetooth 2007 Dakota
Okay, I've searched around a bit and couldn't come up with anything. What I have found is that it is kind of a pain to get an aftermarket head unit into a 2007 Dakota. I like to keep things clean, so I was wondering if anyone knew of any products out there that would give the stock radio the ability to at the very least let me play music/audiobooks from my android to the stock radio via Bluetooth. Currently I'm using the front aux input, but I don't like all the wires all over the place. Anyone have any ideas on this one?
Thanks
Old Feb 15, 2017 | 12:30 PM
Amazon Amazon
Old Feb 15, 2017 | 01:13 PM
doco's Avatar
doco
Well, I was looking for something a little more hidden, that wires directly into the stock head unit.
Old Feb 15, 2017 | 02:37 PM
There are no wires on that and it does not wire into the head unit. It plugs into the 12 volt accessory outlet.
Old Feb 15, 2017 | 03:02 PM
doco's Avatar
doco
Yeah, I know what you are talking about. I guess I was looking for something to tap into the head unit and hide behind the console. I don't like messing with FM frequencies if I'm traveling and start getting interference. It would also be nice to have something that comes on with the truck and turns off with the truck.
Old Feb 15, 2017 | 03:49 PM
doco's Avatar
doco
Here is what I'm thinking so far:
https://www.crutchfield.com/p_541CHY...r.html?tp=1672
https://www.crutchfield.com/p_136911...io-MBT-RX.html
Any thoughts from the community?
Old Feb 15, 2017 | 04:10 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I like my Kenwood. Mine came integral to the radio along with backup camera option.
Find what you like on Crutchfield then shop around for a better price.
Old Feb 15, 2017 | 04:12 PM
doco's Avatar
doco
Is your kenwood a double din? I can't find a double din bezel for an aftermarket on the 07 Dakota. That is the way I'd like to go.
Old Feb 24, 2017 | 01:56 PM
nanohead's Avatar
nanohead
You can fit a double din, but you have to modify the dash bezel. I did it in my 2005. You can also get a single DIN adapter for the 2005-7 and use a single DIN unit with BT, and pull a mic wire up the A piller and locate the mic near the sun visor mount
Old Mar 29, 2017 | 05:04 PM
sparks1032's Avatar
sparks1032
So is anyone running Bluetooth?
