Power Door Locks
Old Feb 26, 2017 | 02:37 PM
markh179's Avatar
markh179
Default Power Door Locks
I have an 2007 Dodge Dakota 4x4 Quad Cab and the power door locks only works on the right rear door only, no other door works including the drivers door. Both driver and pass switch along with the key fob works but only to the right rear door. Any solutions?
Old Feb 26, 2017 | 02:49 PM
p38251's Avatar
p38251
Did you check for broken wires?
Old Feb 26, 2017 | 04:41 PM
00DakDan's Avatar
00DakDan
Section Moderator
Moved to 3rd gen forum.
Old Mar 1, 2017 | 09:35 PM
dodgeman1977's Avatar
dodgeman1977
Did this just happen all of a sudden or were you doing any work on the truck?
Just trying to get some more info, because I have spent hours troubleshooting something then the customer tells me it happened after they did ________. So I have learned to ask before even trying anything, when did it happen and what were you doing before.
I will see if there is anything helpful in the FSM.
