location module ?
Old Apr 14, 2017 | 08:52 AM
pageben745's Avatar
pageben745
Default location module ?
2006 3.7 auto. st dakota, were is the location of the occupant control module ? (orc module) is it hard to change out ? im only average in skill level.
Old Apr 14, 2017 | 09:27 AM
dakotaff's Avatar
dakotaff
Not sure which part that you need (probably the 1st), read below for clarification.
Welcome aboard.
The Occupant Restraint Controller (ORC) (1) is
located below the instrument panel center stack in the
passenger compartment of the vehicle, where it is
secured by three nuts to three studs on a stamped
steel mounting bracket welded onto the top of the floor
panel transmission tunnel just forward of the instrument
panel center support bracket.
The Occupant Classification Module (OCM) (1) is
secured with two screws to a stamped metal mount on
the underside of the passenger side front seat cushion
frame near the center.
Old Apr 14, 2017 | 05:04 PM
pageben745's Avatar
pageben745
ya, need orc thanks
Old Apr 14, 2017 | 07:43 PM
dakotaff's Avatar
dakotaff
I don't think this is something that you want to replace yourself.
Just sayin'.
Old Apr 14, 2017 | 08:04 PM
pageben745's Avatar
pageben745
i decided not to. in penna. it will still pass insp. again thanks fore your help
