EGR / #7 coil melting
Old Apr 19, 2017 | 09:39 AM
mja2k's Avatar
mja2k
Default EGR / #7 coil melting
OK. I've got a good one here. I purchased a 2005 Dakota 4.7 V8 Magnum a few months ago. Had a misfire on #7. along with several EGR codes. Did a complete tune up (coils, plugs, etc)
This engine does NOT have an EGR, however, it does have the connector for it. I drove it for a day..and the #7 went again. It's actually melting. Just to try and eliminate the EGR codes since there is no where to mechanically install the EGR, I went ahead and plugged one up. Codes went away, and #7 stopped melting. Eventually i received the flow code, but it still drove good. Then i received high circuit (P0406), and #7 went again. Can't figure it out.
First question, Is this motor supposed to have an EGR, or did someone replace the head / engine?
2nd question. Why would this be happening. The truck runs fine for a short time, then the #7 coil melts.
Any advice would be great.
Old Apr 19, 2017 | 10:39 AM
ODXBeef's Avatar
ODXBeef
It is absolutely supposed to have an EGR it should be attached to the rear of the left cylinder head. It should be crammed back there between the back of the head and the firewall.
Old Apr 20, 2017 | 08:13 AM
mja2k's Avatar
mja2k
That's what I figured....they must have replaced the head or engine. I suppose the only way to correct the EGR issue is find a head with the EGR ports and swap it. Then I'll have to figure out the meltdown, or maybe that will correct it.
