2006 Dakota Transmission Issue. Truck started up in limp mode
Old May 4, 2018 | 07:00 PM
Ryan Dake's Avatar
Ryan Dake
Seems like this is common. I have an 06 Dakota, same problems. Guess I should skip to checking the FCM and TICM first. My problem is currently very intermittent.
Old May 6, 2018 | 04:31 PM
Chrisj0424's Avatar
Chrisj0424
I would I spent way too much money replacing things that didn't need to be replaced if I were you I would take it and get it and get it diagnosed first you could probably save a lot of money
Old May 25, 2018 | 02:31 PM
Sardonicvs's Avatar
Sardonicvs
Originally Posted by drawde6
45RFE Transmission.
Yesterday my truck started up in Limp mode and the CEL came on. This is not the first time that this has happened. I turned off my truck and restarted it. The truck drove fine after that. I immediately went to o'reillys and read the codes.
I have the following codes:
U0100- Lost Communication with ECM/ PCM
U0101- Lost Communication With Transmission Control Module
P0700- Transmission Control System (Malfunction Indicator Lamp Request)
P1603- PCM Internal Dual-Port RAM Communication Failure
P0882- TCM Power Input Signal Low
P0876- Transmission Fluid Pressure Sensor/ Switch D Circuit Range/ Performance
P0988- Transmission Fluid Pressure Sensor / Switch E Circuit Range/Performance
P0871- Transmission Fluid Pressure Sensor / Switch C Circuit Range/Performance
P0846 -Transmission Fluid Pressure Sensor / Switch B Circuit Range/Performance
P0869- Transmission Fluid Pressure High
Personally, I think it's an electrical issue. Maybe there is an issue with the connectors to the PCM or to the battery. I would like to get a second opinion on this to help me figure out where to start troubleshooting.
I created a spreadsheet with the information from the Factory Service Manual. I would appreciate any help or information. Thanks.
I'm suffering the same issue; damn-near as soon as I rolled over 90k I got the same list of codes. So far, I've replaced:
- PCM - which took care of the P1603 code: no CEL for a week or two and then the other codes came back;
- Transmission filters and fluid, per TSB 21-016-05: this also cleared the code for a few days, and then they came back;
- Changed out the trans control relay, as I read that could be causing the 0882 code.
Since then, I've also received the following codes:
- C2202 - Original VIN Mismatch/Missing; read that this may be a problem with the ABS module;
- C2206 - Vehicle configuration mismatch; read that this might be a problem with the "occupant restraint controller";
- U1414/15 - Implausible/Missing ECU network/Vehicle configuration data.
Most of what I've read points to the 0882 and 1414/15 codes possibly being caused by the TIPM/fuse-block being bad or having issues. I'm planning to do what I can to check all the connections and wiring, hopefully to rule out that as the cause. I've read mixed things about how difficult it is to replace the TIPM, everything from it needs to be specially ordered and flashed by a stealership to simply having to match a part number and turn the key on and off twice to program it. Hopefully I can get enough information to post something helpful.
Old Jun 20, 2021 | 04:09 PM
j_sapience's Avatar
j_sapience
Default same issue 06 dakota
Im having the same issues on a 06 Dakota SLT 4.7l AWD I just picked up. Very strange but identical to the issues described. Can’t find much info or people successfully diagnosing this problem online.. Have any of you managed to locate the problem and get your trucks fixed? I would love to hear some updates on your experiences!
Old Jun 22, 2021 | 10:43 PM
djsilverjohnson's Avatar
djsilverjohnson
I've changed the battery, battery clamps, disconnected and cleaned all grounds, cleaned connections to the ECM/TCM, FCM, fuse box and all fuse box plugs, transmission plug, replaced the ignition switch, replaced the FCM, and replaced the fuse box and still get these errors and transmission in limp mode. I've also had the vehicle security alarm go off twice! It most often happens when restarting the truck hot, or when backing up then switching to drive. I used to trying scanning and clearing codes afterward but have given up. Now I just turn it off, count to 10 and try again. That works 99% of the time.
Old Jun 23, 2021 | 09:37 PM
dakotadadv8's Avatar
dakotadadv8
I have an 06 dodge Dakota v8, original owner. Also have P0700 code and CEL came on but I believe it started when transmission cooling line leaked. Just replaced them and need to make sure replaced enough ATF. Will do some more testing.
Old Jul 8, 2021 | 01:05 PM
Wbross1972's Avatar
Wbross1972
45RFE Transmission.
Has anyone tried changing the crankshaft sensor?
Old Jul 8, 2021 | 01:21 PM
j_sapience's Avatar
j_sapience
I'm not sure, but I have noticed that if I start the engine immediately after putting the key in the ignition the CEL doesn't come on and it doesn't start in limp mode. I read about someone else doing that somewhere and it seems to consistently work for me, I haven't had the CEL come on once since I started doing this; something about starting the engine before the computer can detect and register an error...
I'd still like to get to the bottom of this and figure out what's really going on, but in the meantime this bypass trick has allowed me to focus on other things.
Anyone else having any luck?
Old Jul 8, 2021 | 01:24 PM
Wbross1972's Avatar
Wbross1972
im sorry meant to say cam/crank shaft position sensor?
Old Jul 9, 2021 | 12:55 PM
djsilverjohnson
The one on the flywheel/flex plate will shut the engine off. Leaky rear main seal will coat the sensor with oil and cause it. I changed the rear main seal and it quit happening.
