Mystery Coolant Leak
Old Jul 30, 2017 | 02:09 PM
Mud Marine's Avatar
Mud Marine
Default Mystery Coolant Leak
Hey yall,
I noticed a small puddle of coolant under my Dak the other day and I'm having a hard time locating the source. It looks like its coming down the front of the block which makes me think water pump. Any thoughts on this? Is that a common leak for anyone else? I hate changing water pumps!
Also is there any aftermarket brand I should stay away from? My local dodge dealership is not very responsive from the parts department... And I'm in Hawaii so there is only one...
Old Jul 30, 2017 | 02:35 PM
Water pump on these trucks is about an hour job. Not hard at all. If you think the pump is leaking, go ahead and replace it.
Old Jul 30, 2017 | 03:06 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
There is a blind spot when the WP leak wraps around the crank pulley and goes down. It will throw you off a bit. Do the thermostat while it's apart. You can reach it easily from the top. I typically do the tensioner pulley assembly as well. They tend to start getting noisy after you disturb an old one.
Old Jul 30, 2017 | 04:48 PM
Mud Marine's Avatar
Mud Marine
Thanks for the tip, I might as well knock that out too. This truck is used and the old owner didn't seem to do much preventative maintenance.
