2015 Dakota front parking lightbulb replacement
Old Oct 15, 2017 | 09:52 AM
wozniasm's Avatar
wozniasm
Default 2015 Dakota front parking lightbulb replacement
Typo on the year. It's a 2005.
Any idea how to do this?
Per the Chilton, there's supposed to be an access door in the wheel well and there is not.
Thanks in advance!
Old Oct 15, 2017 | 09:30 PM
Move down to the correct section. They stopped making the Dakota in 2011. Are you sure about the vehicle info you are providing?
Old Oct 16, 2017 | 05:25 AM
wozniasm's Avatar
wozniasm
My bad jkeaton! Typo on my part. It's a 2005.
Old Oct 16, 2017 | 07:54 AM
There are two (or three, can't remember) screws (torx head) holding the headlight assembly in. One is on the inside edge of the light, accessible by opening the hood and moving a rubber flap out of the way. The other one (or two) are on the bottom edge. If you look straight on under the bottom edge of the light housing, you will see a small indent in the bumper cover that will allow you to get at that one. Then the housing pops out.
Here's a thread on it.
https://dodgeforum.com/forum/3rd-gen...t-removal.html
Old Oct 16, 2017 | 08:35 AM
wozniasm's Avatar
wozniasm
Thanks so much jkeaton for the help and location that I should have posted in!
Old Oct 16, 2017 | 08:08 PM
dakotaff's Avatar
dakotaff
An easier way is to lay on the ground and reach up to the bulb, quarter turn, and replace the bulb. Super fast and easy.
Old Oct 17, 2017 | 05:12 AM
wozniasm's Avatar
wozniasm
Thanks dakotaff!
