New front springs from moog or not?
Old Oct 29, 2017 | 11:48 AM
RichLC's Avatar
RichLC
Default New front springs from moog or not?
I'm researching doing a shock replacement and leveling kit for my 05 QC 4.7L 4x4 125K mi
What experience have those that have replaced the OE springs with the MOOG equivalents?
Did you pick up ride height?
Did the spring rates seem the same?
Did you compare the old springs free length with the replacements, if so what was the difference?
Does the quality seem equal or better than the Dodge parts?
Currently the distance between my wheel center and the fender lip is 19.5 inches, is that average?
Old Nov 1, 2017 | 09:21 PM
RichLC's Avatar
RichLC
How about this question;
Anyone know if the spring rates changed anytime during the 3rd generation?
Per the Moog catalog:
2005 Dodge Dakota 4wd
2008-2009 Dodge Dakota
Part No: 81348
Install height: 7.613 inches
Free height: 14.167 inches
Constant rate.
Part No: 81356
2006-2007 Dakota
2006-2007 Dakota RWD 4.7 V8
2005-2007 Dakota 4WD 3.7 V6
2007 4WD
2006 4WD 4.7L V8
Install height: ??
Free height: 13.89 inches
Constant rate.
Old Nov 2, 2017 | 08:33 AM
dakotaff's Avatar
dakotaff
I can't recall anyone replacing the springs. Other than the
<b>Monroe quick strut assembly</b> Monroe quick strut assembly
which comes with springs and ready to install, some members have them. And you would think that there are different springs for either the V6 or V8, the V8 would be a bit lower with the extra weight.
Old Nov 3, 2017 | 10:45 PM
Vladek's Avatar
Vladek
I replaced mine with the moog assembly. yes it did raise the front end enough that I had to take the leveling kit off. It put everything in a bind when making turns on country roads and bumps. I didn't take measurements though. It did make a major difference also, for the better. However, the ones I replaced where also 11 years old.
Old Sep 5, 2018 | 07:50 PM
RichLC's Avatar
RichLC
Here are the specs I got from MOOG:
Part No: 81348
Spring rate: 690 lbs. per inch.
Part No: 81356
2006-2007 Dakota
2007 4WD
2006 4WD 4.7L V8
Driver side spring has a free height of 13.855 inches, spring rate of 690 lbs. per inch.
Passenger spring has a free height of 14.309 inches and a spring rate of 572 lbs. per inch.
Anyone know why the difference mid generation then back again??
