2007 overhead console courtesy lights, glove box lights and ashtray lamp not working
Old Dec 2, 2017 | 11:08 AM
John69AZ's Avatar
John69AZ
Default 2007 overhead console courtesy lights, glove box lights and ashtray lamp not working
Are these all on the same fuse? Which number fuse or label are they under? I did try searching in the forum with no luck. Thanks
Old Dec 2, 2017 | 11:57 AM
dakotaff's Avatar
dakotaff
First off, check that the dimmer is not turned all the way down (by the headlight ****).
Then, check Fuse #25. (Also #6 & 8)
Old Dec 2, 2017 | 02:09 PM
John69AZ's Avatar
John69AZ
Dimmer was in correct position. The rear courtesy light works but the front ones do not. Checked all those fuses and they all appear to be good.
