08 and up gas pedal
Old Dec 16, 2017 | 10:51 AM
Vladek's Avatar
Vladek
Default 08 and up gas pedal
I was wondering if anyone had access to the pin out for the Accelerator Pedal Position Sensor for 08 - 11 Dakotas. If it is the same as the 2010 Ram, I'm good. But I want to make sure first.
This is for my 05 Dakota that is getting the hemi transplant.
Old Dec 25, 2017 | 04:15 PM
DOINGITLARGE's Avatar
DOINGITLARGE
I checked the 2005DodgeDakotaFSM.pdf and the only thing I found was this: The Accelerator Pedal Position Sensor (APPS) is currently used only with the 5.7L V-8 engine.
Old Dec 26, 2017 | 10:27 AM
Vladek's Avatar
Vladek
it would have to come from a 08 or newer FSM.
Old Dec 26, 2017 | 07:05 PM
WvChamp's Avatar
WvChamp
Looked up for an 08 Dakota
Cavity Circuit Function
1= F855 20PK/YL 5 VOLT SUPPLY
2= K23 18BR/WT APPS NO. 1 SIGNAL
3= K4 18BR/LB APPS NO. 1 RETURN
4= K400 18BR/VT APPS NO. 2 RETURN
5= K29 18PK/RDAPPS NO. 2 SIGNAL
6= F856 20YL/PK 5 VOLT SUPPLY
File Type: png
Old Dec 26, 2017 | 07:14 PM
WvChamp's Avatar
WvChamp
Looked up for a 2010 Ram
PinCircuitWire ColorGauge/SizeFunctionOption
A1 F855PK/YL225 VOLT SUPPLY
A2 K23BR/LG22 APP SIGNAL 1
A3 K167BR/YL22 APP SENSOR GROUND 1
A4 K400BR/VT22 APP SENSOR GROUND 2
A5 K29WT/BR22 APP SIGNAL 2
A6 F856YL/PK22 5 VOLT SUPPLY
Connector looks same...possibly blue.
Couple of the wires are different color.
Hope this helps
WvChamp
Old Dec 27, 2017 | 08:29 AM
Vladek's Avatar
Vladek
awesome, thank you. I thought they would be the same (minus wire color), but I wanted to make sure. Plus, I didn't want to get another subscription for just one connector. already have one for the 05 Dakota and one for the 10 Ram.
