Transmission Pan/deep Filter
https://www.amsoil.com/shop/by-produ...?code=58843-EA
This is the filter its meant for a deep pan.
https://www.yourcovers.com/transpan_11044.php
Here is the pan it holds 1.5 quarts more.
I have a 09 Dakota 3.7l. My question is do i need to go with a deep transmission filter.
And yes there is a a deep well trans pan that will fit my truck. I call the manufacturer.
Right on the Yourcovers . com website, it says:
Filter Info
The interior of the pan as a filter support. Use a stock filter with this pan. No filter extension is needed.
Use OEM transmission filters, not aftermarket brands.
Filter Info
If it's any help Dorman makes a 42RLE tranny pan(#265-818) with a convenient drain plug and LubeLocker makes a reusable gasket(#LLT-A042) for it that is a direct bolt on for the Dakota.Makes tranny servicing a breeze imho.
