Help! 2005 Drum Brake Service
Old Jan 16, 2021 | 12:07 AM
tmkf_patryk's Avatar
tmkf_patryk
Originally Posted by Jason.t788
How did you end up doing this? I am currently in the middle of doing mine and cannot seem to fire this out. When I took mine off they had the springs in the same hole but not that far out. They both hooked behind the tensioner.
oh man it's been a while since I did this, just got the email so I figured might as well respond.
I did upgrade the whole set to the TSB (one more spring than original if I remember correctly?)
I also replaced the cylinders.
When putting it back together, I hooked up the rear spring to the both shoes and then put them into the brake system, but hard to stretch it a bit to make it fit
Old Jan 17, 2021 | 07:57 AM
philipat's Avatar
philipat
DIdn't realize that there's a TSB out for the rear brakes. You wouldn't happen to have the TSB number, would you?
