clutch noise. rhythmic chirping/squeaking on lift throttle
Old 05-16-2018, 08:46 AM
rookie's Avatar
rookie
rookie is offline
Default clutch noise. rhythmic chirping/squeaking on lift throttle
like the title says. when i lift the throttle, as if to coast while in gear, i get a chirp chirp chirp or squeak squeak squeak from under the truck--assuming its the clutch. changes with truck speed not engine speed. only does it when coasting forward or driving backward, so it is a directional thing. coasting in reverse while in gear does not produce the sound, nor does accelerating forward while in gear
im assuming its a bad bearing, but would like to know more
yes i have too big tires and a stupid .355 rear end. i try to go easy on the clutch. 60k miles
Old 05-16-2018, 09:09 AM
jkeaton is offline
Dodge Forum Administrator
Sounds like a TOB.
Old 05-16-2018, 11:17 AM
rookie's Avatar
rookie
rookie is offline
yay. thanks for the hasty reply
im planning a hemi swap for the future, maybe the future is here
Old 05-16-2018, 12:16 PM
jkeaton is offline
No time like the present!
Old 12-29-2018, 11:26 AM
Richard Begley's Avatar
Richard Begley
Richard Begley is offline
I have a 2012 5.7 hemi charger with a load chirping sound at idle any ideas what it could be
Old 12-30-2018, 01:53 AM
FaceDeAce's Avatar
FaceDeAce
FaceDeAce is offline
The rattle / chirp at idle is often the PCV valve. Though on most 5.7 hemi the PCV is in a place (behind the throttle body) that any sounds from it should not eminate far. Perhaps check where it is on your charger and if it is right up at the firewall, that could be what you are hearing. Other things making chirps and squeaks are related to the serpentine belt. Bearings in the tensioner idle wheel, alternator, other.
Sounds like you just need to spend some time under the hood look and listening.
Quick Reply: clutch noise. rhythmic chirping/squeaking on lift throttle
