07 Dodge Dakota Misfire(???)
Old May 23, 2018 | 06:20 PM
Danny Vines's Avatar
Danny Vines
Default 07 Dodge Dakota Misfire(???)
I have a 07 Dodge Dakot 4.7 V8 that has a problem that I just can't figure out. Whenever the truck warms up after driving for a bit or idling it starts acting like there is a misfire... low power, hiccups in acceleration and then the check engine light start flashing for a little while. Then sometimes it will just be perfectly normail. I changed spark plugs, ignition coils, throttle position sensor and I've taken it to two different shops with no luck. Please help!!
Old May 24, 2018 | 07:38 AM
Have you checked for stored codes? If you've taken it to two different shops and they can't figure it out, probably a bunch of wag's on a forum wont help you out much.....try a dealer with the proper equipment.
