How do i get gear ratio
Old Jun 18, 2018 | 09:19 AM
Jugalug's Avatar
Jugalug
Default How do i get gear ratio
2005 dodge dakota 4x4
vin 1D7HW48N45S305091
Old Jun 18, 2018 | 09:32 AM
dakotaff's Avatar
dakotaff
Here is your build sheet, you have 3.55 gearing, at least as built from the factory. Don't get excited about anything listed as 'Heavy Duty', that's all just standard equipment.
Welcome aboard.
Old Jun 18, 2018 | 12:53 PM
daktwos's Avatar
daktwos
To verify you can jack up the back, mark the driveshaft and wheel.With the trans in neutral rotate the shaft one revolution and note how many times the wheel turns.
Old Jun 19, 2018 | 09:36 AM
superdak05's Avatar
superdak05
open up the glove box and there should be a sticker on the inside bask with that info, or go to allpar.com and type in your vin.
