seat belt light
Old Sep 25, 2018 | 08:18 PM
KCRY's Avatar
KCRY
Default seat belt light
hi new to the forum i have a 2005 dodge dakota SLT quad cab 4.7 the light for the seat belt came on one day and stays on all the time now. ive unplugged the harness underneath the drivers seat and the light is still on. could anyone please help lead me in the right direction to get this light off on my dash. i have OCD and cannot stand having lights on on my dash. LOL thanks everyone
Old Sep 26, 2018 | 07:51 AM
IIRC, the circuit needs to be closed to turn the light off.
Old Sep 26, 2018 | 08:30 AM
KCRY's Avatar
KCRY
What does that mean ? How do I do that ?
Old Sep 26, 2018 | 09:09 AM
northgator8's Avatar
northgator8
Imagine a switch. When the switch is off, it is OPEN o \o When it is on, it is CLOSED o--o. The control system for the light is looking for a signal back from the seat belt harness that shows a continuous loop - CLOSED. When there is a failure i.e. the seat belt is not connected, it is OPEN. For an unsafe, temporary fix, put a jumper across the disconnected connector. For a safe, permanent fix, find the wire that has worn through and come apart and repair it. Use the search function on this forum to find the repair that others have carried out.
Old Sep 26, 2018 | 10:32 AM
KCRY's Avatar
KCRY
Thank you I appreciate it
Old Sep 26, 2018 | 06:29 PM
KCRY's Avatar
KCRY
i have got the light to go out using a jumper wire ,but how does one fix it properly? ive checked all wiring and none are worn or pulled out or damaged. do i need an actual new seat belt buckle? thank you
Old Sep 27, 2018 | 07:22 AM
northgator8
I would look at the wiring under the seat. You may have to take the seat out and follow the wires from the connector through to the seat belt buckle. The fact that you have been able to jumper the connector to fix the problem has isolated the open circuit.
