Bleeding brakes
Old Sep 30, 2018 | 01:41 PM
Mapkrk's Avatar
Mapkrk
Default Bleeding brakes
Hi,
Whats the best way to bleed whole system with ABS pomp. I don't have software to activate ABS pomp for bleeding, is there any other way for bleeding brakes ?
Regards,
Old Sep 30, 2018 | 08:36 PM
philipat's Avatar
philipat
Take a look at page 5-5 in the Factory Service Manual. There's a link to it in one of the stickies. I think the thread is titled something about the Factory Service Manual
Old Sep 30, 2018 | 10:23 PM
primem's Avatar
primem
what year is the truck?
why do you need to bleed the abs pump?
I would not try to "backyarder actuate" the abs pump. If abs bleeding is required and you don't have a scan tool...have it done professionally.
Price it out.....consider a autoengiuity laptop based scan tool...it can do this and the Chrysler package is around $350. Shop would probably charge 1 hour labour $130 depending on the door rate. make sure all the bleeders are freed up...if they break or are seized...more time or even a calliper/wheel cylinder.
