Brake pedal
Old Oct 5, 2018 | 07:45 PM
KCRY's Avatar
KCRY
Default Brake pedal
I recently discovered a bad wheel cylinder the abs and brake light came on so I changed the wheel cylinder and bleed the brakes. I still have a fading pedal at a stop and when I pump it it gets hard and functions properly. I have no leaks and master cylinder is full with no leaks what is the issue? Thanks for the help
05 Dodge Dakota
4x4 slt 4.7 quad cab
Old Oct 5, 2018 | 11:54 PM
rodslinger's Avatar
rodslinger
Did you adjust the rear shoes back up?
Old Oct 6, 2018 | 02:58 AM
KCRY's Avatar
KCRY
How is that done ? Thanks
Old Oct 7, 2018 | 10:11 AM
Jaded's Avatar
Jaded
Thats usually a sign of failed master cyl. A bad brake hose, Or brake fluid gone bad. Have you flushed the fluid?
Old Oct 7, 2018 | 11:25 PM
rodslinger's Avatar
rodslinger
Originally Posted by KCRY
. I still have a fading pedal at a stop and when I pump it it gets hard and functions properly....
Clarify. Fading brake pedal or soft pedal? If you pump it up to a firm pedal will it stay firm or fade again if you keep holding?
