High Rmps
Old Oct 7, 2018 | 11:07 AM
Cathy M's Avatar
Cathy M
Default High Rmps
I have a 2010 Dakota. Everything works fine except while im driving the rmp's won't drop. When im going about 45 mph the rmp's won't go below 3200 rpms.
Old Oct 7, 2018 | 12:39 PM
not going into overdrive?
Old Oct 7, 2018 | 12:45 PM
Cathy M's Avatar
Cathy M
I'll be honest I don't think it has overdrive. It goes into drive and reverse no problem. It doesn't shift while im driving.
Old Oct 7, 2018 | 12:54 PM
Cathy M's Avatar
Cathy M
Im thinking it might be speed sensor
Old Oct 7, 2018 | 02:41 PM
If you have an automatic, there is an overdrive gear
Old Oct 8, 2018 | 09:06 AM
dakotaff's Avatar
dakotaff
  1. Check your transmission fluid, being low could cause it to hang on to a gear.
  2. Reset your PCM by disconnecting the battery for a while, and turn the truck to 'On' to help drain the system. This reset may remedy the issue.
  3. If the first two don't help, then change the transmission fluid and filters. There are two trans filters, and use OEM filters, not aftermarket filters.
