Driver side interior door panel.
Old Dec 21, 2018 | 11:07 PM
BillPa's Avatar
BillPa
Default Driver side interior door panel.
Does anyone know if just the center section of the driver's side door panels are replaceable? I fixed(?) the armrest on mine sometime ago but....... I've located complete panels but none so far with speakers in the A pillars.
Bill
Old Dec 22, 2018 | 07:35 PM
Hesselhoff's Avatar
Hesselhoff
If you know how to plastic weld and can identify the plastic used, yes. The pegs are put through and essentially riveted with a hot iron. I think somebody on here used the a-pillar from a ram and a heat gun to make it fit.
Old Dec 23, 2018 | 03:33 PM
stetson's Avatar
stetson
Plastic weld? Pfft drill the studs and clamp everything in place then fill with jb weld or a similar epoxy (wouldn't use jb qwik though)
Also here is the door panel with the tweeter.
https://www.factorychryslerparts.com...MaAs9zEALw_wcB
Old Jan 12, 2019 | 09:40 AM
ReliableBlue06Dak's Avatar
ReliableBlue06Dak
My 2006 driver's side is cracked at the point where my elbow rests. Can I ask how you fixed it?
Old Apr 30, 2019 | 08:12 AM
danesmess's Avatar
danesmess
Default I fixed mine with JB Weld Plastic Weld
Mine did the exact same thing where my elbow was always placed. Plastic underneath cracked and piece actually fell out, but did not tear the pleather skin. Took the interior door panel off and flipped it upside down and used JB Weld Plastic Weld. Just make sure you layer it on thick and bond it with some good plastic. You can even put pieces of metal across the crack and epoxy them in for extra support. I've had no problems with mine for the past seven months.
Old Dec 17, 2019 | 10:40 PM
ReliableBlue06Dak
I did exactly like Danesmess, but on mine the pleather cracked, so there are hard seams that are a bit scratchy. Other than that, it's working great!
