Transmission problems
Old Jan 8, 2019 | 04:29 PM
pilotsmack's Avatar
pilotsmack
Transfer case isn't in neutral? Put it in 4wd and back to 2wd/awd to check if the TC is able to switch... if the lights keep flickering, it could be a transfer case issue and not a transmission issue.
Musta been one heck of a bump!
Old Jan 8, 2019 | 08:38 PM
hammertime3613's Avatar
hammertime3613
Thanks,I’ll try that. It really wasn’t much of a bump.
Old Jan 11, 2019 | 08:17 AM
hammertime3613
It goes into 4wd. I can hear it switching. Does the transmission have any sensors or solenoids on the outside of it.
Old Jan 11, 2019 | 05:57 PM
pilotsmack's Avatar
pilotsmack
The no codes part is so weird. Even a cracked filter usually throws a P0841 or something.
There is an input sensor and an output sensor. The solenoids are inside the trans, but the plug for them is external.
Do you have 2wd? Or AWD?
Old Jan 11, 2019 | 06:39 PM
pilotsmack's Avatar
pilotsmack
Another thought - Did the bump disconnect your gearshift selector cable at the transmission? If you put the truck into N, does it roll? Or does it stay parked?
Old Jan 12, 2019 | 08:30 AM
superdak05's Avatar
superdak05
try this, disconnect the battery for 20 minutes and let everything clear, like and electrical component it may just need a reset.
Old Jan 12, 2019 | 11:30 AM
hammertime3613
It’s 4wd. The cable is connected and it changes gears. No matter what gear I put it in it still is in neutral. Park works?
Old Jan 12, 2019 | 07:05 PM
hammertime3613
I don’t understand why it isn’t throwing a code. Wouldn’t it throw a code if it was a sensor or a solonid????
