2006 Dakota engine fit into the 2005
Old Feb 28, 2019 | 10:35 AM
g012170's Avatar
g012170
Default 2006 Dakota engine fit into the 2005
Greetings. I have a 2005 Dakota SLT with a 4.7 in it. Apparently the engine spun a rod, (I’m not a mechanic but it sounds serious) and mechanic said it’s best to swap out the engine vs rebuild/overhaul. My question is, can I put an engine from a 2006 Dakota into my 05. I’ve heard from a friend that yes because the 05-07 are the same series and the parts are interchangeable.
Any guidance would be greatly appreciated.
Old Feb 28, 2019 | 10:48 AM
Should bolt right up.
Old Mar 1, 2019 | 11:02 AM
g012170's Avatar
g012170
Thanks jkeaton. Your response is greatly appreciated.
Old Mar 2, 2019 | 09:21 AM
RicOshea's Avatar
RicOshea
Upgrade to a H.O. J code ... \o/
