05' Dakota - Front Shock/Strut Assembly
Old Mar 26, 2019 | 06:32 PM
Typheous890's Avatar
Typheous890
Default 05' Dakota - Front Shock/Strut Assembly
Hey all,
The shocks in the front have finally worn out! Shops asking for a grand to replace the front end. (No way)
I've been researching online that you can buy a full assembly. (Shock / Spring install) I've heard this is fairly easy to install as a full assembly. But I'm having difficulties telling the difference of what would be better.
I do casual off road driving, nothing crazy. Mainly to get out to the lakes.
I've found 3 assemblies that appear to be compatible with my Dakota.
https://www.autozone.com/suspension-...front/765849_0
https://www.autozone.com/suspension-...4_122078_2888#
https://www.summitracing.com/parts/s...e/model/dakota
Truck Specs
2005 Dodge Dakota SLT Quad Cab
4.7L Magnum V8
4WD , 3.92 Axle Ratio
No lift kits, all standard.
Let me know what you all think, thank you!!
Old Mar 26, 2019 | 09:37 PM
dakotaff's Avatar
dakotaff
Look for Monroe quick struts, don't know the part number off hand.
Old Mar 26, 2019 | 09:58 PM
Typheous890
Hey there,
Thanks! I found them on Amazon! Have you used these before? I'm hoping they're a good pick for light off roading.
I added the link in case you wanted to see >>
Amazon Amazon
Old Mar 27, 2019 | 07:49 AM
dakotaff's Avatar
dakotaff
Originally Posted by Typheous890
Hey there,
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Those are the ones. Monroe and Rancho are the more popular brands around here for an upgrade, with Rancho being a bit stiffer than the Monroes. Rancho does not include the whole spring assembly though, only the strut itself. I went with the
<b>Rancho</b> Rancho
, but you'll be happy with either choice.
Old Mar 28, 2019 | 11:07 AM
RicOshea's Avatar
RicOshea
say Dakotaff, just curious what spring and strut mount did you use for your rancho struts. I myself used moog springs and mount. Not entirely happy with the spring though. I tried to match it with a rancho spring but couldn't get any specs from Rancho themselves nor did their tech service return any emails or phone calls.
Old Mar 28, 2019 | 01:11 PM
pilotsmack's Avatar
pilotsmack
My Ranchos just arrived. Got the Moog mounts and some variable rate springs from ACD. Let you know how it goes. I am on call until Sunday night, so the earliest I will be able to wrench will be Monday, incase work needs me.
Old Mar 28, 2019 | 03:15 PM
dakotaff's Avatar
dakotaff
It's usually a PITA for the install, give yourself plenty of time to do it.
I reused the springs and mounts, no issues at all since, and that was 10 years ago (yup, 10 yrs). I gave the struts to my mechanic, after reading about the issues and headaches for installing them.
I figured let him have all the fun.
He took all day, I picked up my truck later than they usually close, so I'm sure it did not go too smooth.
Old Mar 28, 2019 | 03:44 PM
pilotsmack's Avatar
pilotsmack
Yeah I read about the lower shock bolt. That's why I'm waiting for a day off instead of an on-call day. It already looks like I'm gunna get called in this weekend anyway. I got new Moog bolts and bushings, so I figure I'll let the 5lb dead-blow do the talking
Old Apr 2, 2019 | 12:49 AM
pilotsmack's Avatar
pilotsmack
Oh yeah, that was fun. Those lower strut bushings are absolutely a headache and a half. Had to use a reciprocating saw to take the forks off the bottom, then used a ball joint press to push the bolts out the back, and the bushing out the front. Ate up most of my day, though I did have to wait for the plumber for a good chunk of the morning, and can't hear him from my shop.
Rear shocks and sway bar links done, front shock/strut/bushing and sway bar links, total time was about 8 hours. Rears were a walk in the park by comparison.
Had to put the tools away because the gf works early tomorrow. Just torque-ing and a test ride, and she's done!
Mmmmmm fresh parts
Old Apr 2, 2019 | 04:51 AM
Bruinsdanny's Avatar
Bruinsdanny
Default I'm next
Mmmmmm fresh parts
Sweet I'm doing mine tomorrow! 05 Dakota 4.7L 4x4. I'm worried though because I bought the Rancho struts and need to remove springs and top plate to reuse on the ranchos. Never done it b4. Prior owner installed some cheap "Quick-Stop" branded struts, not to be confused with "Quick-Strut" from Monroe LOL dont even know if I can use the springs from this assembly guess I'll find out tomorrow...😬
