My "New" Truck
Old Apr 9, 2019 | 10:10 AM
Alexandre Plouffe's Avatar
Alexandre Plouffe
Default My "New" Truck
Hello All! I'm new here so lets start by telling you a bit about me.
Always been a GM guy, Live in Northern Quebec(Canada) and recently had major financial issue so i had to return my 1 years old Chevy Volt. Before that i had 2 Brand New GMC Sierra.
A friend of mine sold me his 2006 Dakota for dirt cheap, because he bought a Brand New Ram Eco Diesel.
So for 3000$ CAD (2300$ US) i now have a 2006 Dakota Quad Cab, V8 4x4 with 132000KM (82k Miles)
Truck is clean for the years, Got a tonneau Cover, HID, Helper bag in the rear, Brand new Exhaust.
Since he just put new Tire and Wheel on it, his gonna keep them and give me the new Tire and Wheel that came with the Ram.
Now, i found the Build Sheet on this site, which is awesome, but there is 2 package i can't seem to know what they are.
-Customer Preferred Package 2TC
-Customer Preferred Package 26C
Here is the Full List:
VIN 1D7HW28N16S632778
Vehicle Description 2006 DODGE DAKOTA ST QUAD CAB 4X4
Monotone Paint
136 Amp Alternator
Battery Run Down Protection
Pwr Disc/Drum Rr Anti-Lock Brakes
Rear 60/40 Folding Seat
Advanced Multistage Front Air Bags
Front Seat Area Carpet
Passenger Assist Handle
Driver Assist Handle
Vinyl Door Trim Panel w/Map Pocket
All 5-Speed Automatic Transmissions
205MM Front Axle
3.55 Rear Axle Ratio
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Rear Fixed Window
Rear View Day/Night Mirror
Driver Side Sun Visor
Passenger Side Sun Visor w/Mirror
5 X 7 Mirrors
Sentry Key Theft Deterrent System
Air Conditioning
Instrument Panel
Instrument Cluster w/Tach
200 KPH Primary Speedometer
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Power Outlet Mounted in IP
RADIANT SILVER MET. C/C - Badge -
EXTERIOR COMPONENT COLOR
Key in Ign/Seat Belt Warning Buzzer
Headlamps On Warning Chimes
Low Washer Fluid Warning Signal
Door Ajar Warning Lamp
Map/Dome Reading Lamps
Rear Dome w/On/Off Switch Lamp
Daytime Running Headlamps, High Beam
Cargo Lamp
CHMSL Lamp
Dark Gray Rear Bumper
Dark Gray Front Fascia
Bright Grille
Ram's Head Badge
Black Windshield Moldings
Dakota Badge
EVAP Control System
22 Gallon Fuel Tank
Engine Block Heater
Next Generation Engine Controller
Atlantic Blue Pearl Coat
4 Speakers
Fixed Long Mast Antenna
AM/FM Compact Disc Radio
Power Rack and Pinion Steering
Luxury Steering Wheel
Heavy Duty Suspension Front
Heavy Duty Shock Absorbers Rear
Front Stabilizer Bar
Rear Stabilizer Bar
Full Size Spare Tire
Tire Carrier Winch
P245/70R16 BSW On/Off Road Tires
16X7.0 Styled Steel Wheels
Pickup Box Occupant Classification System
Scissor Type Jack
Brake/Park Interlock
Instrument Panel Parts Module
Tire & Wheel Parts Module
Build To Canada Mkt. Specifications
GVW Rating - 6010#
Canada Dealer Retail
Zone 22-Canada-Quebec
Four Wheel Drive (4WD)/(4X4)
Price Class L
5 FT. Cargo Box
Quad Cab
ND-Vehicle Family
Vehicle Order Tracking
Canada Specifications Label
Quebec Province Code
Cloth 40/20/40 Split Bench Seat
Med Slate Gray
Heavy Duty Service Group
Skid Plate Group
Trailer Tow Group
Convenience Group
Mutually Exclusive Package
750 Amp Maintenance Free Battery
Manual Driver Lumbar Adjust
Front & Rear Floor Mats
Center Armrest Storage
5-Spd Automatic 545RFE Transmission
Lock-Up Torque Converter
Elec,Shift-on-the-Fly,P/Time T/Case
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
4.7L V8 MPI Engine
Left Manual Mirror
Right Manual Mirror
Power 6-Way Driver Seat
50 State Emissions
Federal HDV1, Cal. MDV 1 ULEV II
Aux In-Tank Transmission Oil Cooler
Power Steering Cooler
Speed Control
Heavy Duty Engine Cooling
Tilt Steering Column
Goodyear Brand Tires
16" Steel Spare Wheel
T-Case/Frt Suspension Skid Plate
Tow Hooks
Fuel Tank Skid Plate Shield
Class IV Receiver Hitch
7 Pin Wiring Harness
French/Canadian Language
Under Rail Box Bedliner
4 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Federal A/C Excise Tax
Old Apr 9, 2019 | 01:04 PM
Welcome to DF!
Old Apr 9, 2019 | 01:11 PM
Alexandre Plouffe
Originally Posted by jkeaton
Welcome to DF!
Thanks!
Old Apr 9, 2019 | 01:30 PM
dakotaff's Avatar
dakotaff
I'm pretty sure that:
  • -Customer Preferred Package 2TC = Tow Group Package
  • -Customer Preferred Package 26C = 4.7 and 545RFE Transmission (Optional Equipment)
Welcome aboard.
Old Apr 9, 2019 | 01:44 PM
Alexandre Plouffe
Here is a picture of it!
Old Apr 9, 2019 | 01:45 PM
Alexandre Plouffe
Welcome aboard.
Thanks! So i guess no TRX package? appararently Swaybar bushing are not the same and in need to be replace.
