Torque Specs.
Old May 5, 2019 | 10:54 AM
ramcharger499's Avatar
ramcharger499
Default Torque Specs.
Tore my front end apart to give my Kota some much needed new parts. Both outer tie rod ends are being replaced (inners are solid) and all 4 ball joints are being replaced (upper control arms for your upper ball joints). It's all going surprisingly smooth. Very minimal rust for a Michigan truck. Seems my wife's Uncle rarely drove it in the winter. But, I do need to know if anybody has torque Specs for both upper and lower ball joint castle nuts, tie rod end castle nuts, upper control arm nuts and the axle/hub spline nut. Then I can wrap this little project up.
Old May 5, 2019 | 02:11 PM
I just run 'em in nice and tight, and then tighten a bit more to get the hole for the cotter key lined up.
Old May 5, 2019 | 02:18 PM
dakotaff's Avatar
dakotaff
Follow the link below, the Factory Service Manual will have all of the information that you could ask for.
