Body Lift Kits on 06 TRX 4x4 dakota
Hi guys,
Ive done some searching and have found pretty conflicting answers about whether some lifts will work with the TRX package. I’m not sure what makes installing lifts on TRX Dakota’s any different than regular 4x4 Dakota’s. As most of you know, lifts that fit 3rd gen dakotas are pretty limited. Here is a kit I’m considering: https://www.ebay.com/itm/DAKOTA-05-1...MAAOSwQjZXP1gQ
I confirmed I have the correct rear axle size. I messaged the seller and asked them if there’s any reason this wouldn’t fit an 06 TRX model. They said no. But I have read on other vendors sites that the front body lift cannot be over 2.5”. Anyone have experience with this? Anything you guys can think of?
There is no difference in the suspension on the TRX model compared to any other Dakota. Most guys go with the 3" body lift made by Performance Accessories. Below is shown what came with the TRX packages below, for the 2006 model year.
The Heavy Duty Service Group includes a 750 amp battery, and in-tank transmission and power steering cooler.
Welcome aboard.
Welcome aboard.
The 2.5 in front lift limitation is due to CV and Tie rods being at a severe angle causing premature failure. Keeping the front lift using spacers such as on this kit at around 2 with a max of 2.5" will help to not make the CV's grenade themselves. or lowering the differential to reduce the angle also helps.
I'll admit I have zero experience with lift kits so this might be ignorant, but how is that kit considered a suspension kit? Is it just because it includes new rear shocks? The front sruts will be exactly the same. As far as I can tell the chassis/frame will be exactly the same distance from the ground. The front strut spacers will just fit in between the top of the strut and the point where the strut mounts to the body thus increasing the distance between the body and the wheels, chassis, etc. Aside from the new rear shocks there are no suspension components included in the kit. Am I missing something?
Trending Topics
this is a link to a body lift kit Performance Accessories PA60163. This lifts the body higher, the suspension is not modified at all keeping the frame at the same height from the ground.
