Cam/crank sensor Help
Old Jul 26, 2019 | 09:13 PM
hillbilly0262's Avatar
hillbilly0262
Default Cam/crank sensor Help
I have a 2006 Dakota 4.7 slt. About a year ago going down the road it died I restarted it and it didn't seem like it was shifting. Then I noticed the cruise wouldn't work. I done some research and found out that people was saying to replace the cam sensor so I did and that fixed it. Over the next year I put four cam sensors in it. Now changing the cam sensor don't help it will shut down when ever it feels like and the cruise only works part time. I also put a new crank sensor, new ignition switch module in it when I got it it already had a new computer. I don't know what else to do.
Old Jul 27, 2019 | 07:45 AM
Moved to the correct section. Had it scanned for codes?
Old Jul 27, 2019 | 07:48 AM
hillbilly0262
The only code it showed was p0058
Old Jul 27, 2019 | 08:20 AM
superdak05's Avatar
superdak05
your new ecm could be crapping out already
Old Jul 27, 2019 | 11:24 AM
erau's Avatar
erau
Are you using aftermarket sensors/electronics or OEM? Do *not* use aftermarket sensors/electronics for anything engine/powertrain-related on these trucks...We've heard plenty of repeat-horror stories in the past from people doing that.
OEM only.
Old Aug 8, 2019 | 12:32 PM
JCinTenn's Avatar
JCinTenn
OEM only.
I wholeheartedly agree with this. I replaced both the cam and crank sensors in my truck with aftermarket from the local parts store. Truck didn’t run correctly and I ended up ordering the Mopar ones. Zero problems since I put the OEM ones in.
