No Dash lights, no crank
Old Jul 28, 2019 | 09:48 AM
raythecaddie's Avatar
raythecaddie
Default No Dash lights, no crank
I have 2006 Dakota V8 which ran perfect Friday then on Saturday I go to start my truck and there is no dashboard lights, no crank, so I figured I left the lights on and killed the battery. I have a battery tester and the battery is good and fully charged. The situation never changed even when I tried to boost it, still no crank. Could it be as simple as fuse? Please anyone.
Old Jul 28, 2019 | 11:13 AM
dakotaff's Avatar
dakotaff
I would definitely check the fuses first, all of them one by one.
Old Jul 29, 2019 | 05:20 AM
erau's Avatar
erau
Your battery may be so degraded that even with a jump, it no longer passes enough continuity through it to allow the electrical system to carry the amount of amperage a jump requires...even if the battery may be still reading sufficient voltage.
How old is the battery? Even the results from a battery "tester" used on these trucks sometimes seems to be deceiving.
