Isn't the Prestone green? Only asking cuz the stock stuff is orange. And as mentioned, mixing: Bad.
Also thinking flow issues. How's the routing of the hoses? The lower hose was an absolute bear for me.
Ethylene and Propylene based coolants are colored different colors. We ran Toyota lift trucks at work for years but their coolant was red but Ethylene based like the green stuff. It turned a muddy brown when you top it off with the green stuff, even though it's only the color that's different.
I would drain the system and flush it out using distilled water and a pump, flush out the radiator, heater core, engine, and hoses. Then I wold start with some brand new correct for your engine coolant. If the radiator was used prior and not a "brand new" radiator I would consider replacing it. I myself always run a lower temp T-Stat than the factory whether it's a 180 or 160 T-Stat.
