Ram CV's???
Old Jan 11, 2020 | 08:53 PM
Bruinsdanny's Avatar
Bruinsdanny
Default Ram CV's on the Dakota???
So I spent hours searching never really found a clear answer. There's been much talk about using Ram CV axles on 3rd gen 4x4 dakotas when installing leveling kit. I am going to replace my entire front differential assembly has the shaft on driver side differential snapped inside the CV axle and on the passenger side the front differential assembly mount has also broken. So that diff is no longer any good. I have ordered the replacement front differential assembly. I was wondering if I should buy Ram CV axles instead of Dakota CV's. I will also be replacing both upper control arms, thinking of going with Moog CK series any Intel or info will be much appreciated.
So my question is can I just use Dodge Ram CV axles alone with my Dakota OEM assembly for better articulation when offroad in 4×4?
..05 DAKOTA ST CREW CAB 4.7L 4X4
Supreme Suspensions leveling kit
Leveling kit completely installed with Rancho Shocks and struts & 265/75/16 A/T's
Supreme suspensions full leveling kit. 2 inch front 1 inch rear with pinion angle shims
Passenger side front differential mount bracket
Driver side differential shaft snapped
2in. up front, 1in. Block in rear with pinion angle adjustment shims..
265/75/16 A/T's on OEM 16x7 Wheels
