2005 Dakota 4X4 Tire Pressure Decal
Old Feb 22, 2020 | 11:34 AM
hillisro's Avatar
hillisro
Default 2005 Dakota 4X4 Tire Pressure Decal
Hi - I have an '05 Dakota crew cab 4X4 4.7L V8 mostly stock . It is a bare-bones SL (even has hand-crank windows) - The door jam sticker in my vehicle was completely wiped clean at some point in the truck life and I am just looking for the MFG Recommended tires and pressures. Anyone have access to a similar model that could provide me with an image or details from the sticker? Thanks!!
Old Feb 22, 2020 | 12:27 PM
dakotaff's Avatar
dakotaff
Your truck (ST, not SL) came with P245/70/16, other models came with P265/70/16. Either size will fit on your ST, the 265s just look a lot better on the truck. The door sticker says to run at 35psi, but almost all of us run closer to 40psi, but anywhere from 35-40 is fine.
Welcome aboard.
Here is a sticker from a similar Dakota.
Old Feb 22, 2020 | 12:36 PM
RicOshea's Avatar
RicOshea
dakotaff has a link to the official build sheet for every truck. You can ask him to link (I don't have) it but as far as I remember My original tires were 'Goodyear AT's' 265/65/R17 @ max. 80 psi
Old Feb 22, 2020 | 01:13 PM
hillisro's Avatar
hillisro
I have the build sheet for my VIN so I knew the right size and the pressure is as I assumed - Thanks for the confirmation!!!
