Rancho, KYB, Monroe, ???
Old Jun 3, 2020 | 04:45 AM
philipat's Avatar
philipat
Originally Posted by mtnman82
Moog quick strut assemblies: ST8610(2WD) and ST8623(4WD)
Thanks!
Quick question: did the front suspension change in 2010? The Moog struts are listed as use on 2005-2009 Dakotas. They don't list any struts for 2010-2011. I did a quick check and the Monroe quick struts are listed the same way - only 2005-2009, nothing for 2010-2011.
Old Jun 3, 2020 | 08:24 AM
Originally Posted by philipat
Thanks!
Quick question: did the front suspension change in 2010? The Moog struts are listed as use on 200-2009 Dakotas. They don't list any struts for 2010-2011. I did a quick check and the Monroe quick struts are listed the same way - only 2005-2009, nothing for 2010-2011.
Nothing changed.
Old Jun 3, 2020 | 02:13 PM
mtnman82's Avatar
mtnman82
Originally Posted by RicOshea
I had the RS5757 struts and replaced them with the Monroe Quick strut. I would of gone with Moog struts had I known about them plus I had just replace the entire front suspension with Moog
Why did you replace the Rancho's? And the Moog struts are better than the Monroe?
Old Jun 3, 2020 | 03:56 PM
lantzd's Avatar
lantzd
mtnman82 - all of the parts I got were Moog through Amazon. I got swaybar endlinks (K750263), stabilizer bar bushings (K201621), tie rod ends (ES3571), upper control arms (CK620006). I plan to also get the Moog quick struts (ST8623), Moog wheel bearings (513229), and maybe even Moog lower control arms (RK620479/RK620478). It might all be overkill, but I really want a better riding front end and figure since I am in there I might as well replace it all.
Old Jun 3, 2020 | 08:05 PM
philipat's Avatar
philipat
Originally Posted by jkeaton
Nothing changed.
Cool! Thanks.
Old Jun 22, 2020 | 11:39 AM
mtnman82's Avatar
mtnman82
Rancho's on all 4 corners. Ride is definitely NOT too stiff. In fact, front could be a tad stiffer for my tastes. Original shocks/struts (red in color) were shot. Rides much smoother than before. I also put on new tires, proper LT 265's, so I'm sure tht has something to do with it too.
You MUST use stock/OEM upper strut mounts with the Ranchos. The Moog upper mounts did not fit. I did have the Moog lower strut mounts pressed in with no issue.
