single chime upon startup
Whenever I start my car, whether I have my seat belt buckled or not, I hear a single chime after I start the engine. No dash lights. No codes or pending codes. Anybody know why this might be?
Do all of the dash lights do a test after start? Should be a bunch of them, and I think that's what the chime is. Airbag, ABS, 4x4, Trans Temp... bunch of em. Might be that it is still testing, but the light isn't working.
It's your Oil Change Reminder, which will come on after approximately 3000 miles.
Info from your Owners Manual:
Change Oil Message
Your vehicle is equipped with an engine oil change indicator system. The “Change Oil” message will flash in the instrument cluster odometer for approximately 12 seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position.
To turn off the message temporarily, press and release the Trip Odometer button on the instrument
cluster.
To reset the oil change indicator system (after performing the scheduled maintenance)
refer to the following procedure.
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
Next time you start up, the 'chime' will be reset, and gone.
Change Oil Message
cluster.
Interesting. I don't see the 'change oil' in the odometer window when I start, certainly not for 12 seconds. About to go install the new rear shocks in a bit. I will pay close attention upon startup and report back...
First startup of the day, forgot to put my seatbelt on before starting. You can hear the single delayed chime. No change oil on the odometer display. After waiting a minute I recorded startup again with the seatbelt on. Single chime with nothing on the dash. It does the same thing with the parking brake off.
Trending Topics
Long shot...do a code scan yet? There are a few "single chimes" mentioned in the owner's manual and it could be that a warning light on the dash doesn't work, for whatever reason. But, there might be some codes to help.
