06 4.7 cam swap questions
Old Jun 24, 2020 | 11:41 AM
Monkey 13's Avatar
Monkey 13
Originally Posted by RicOshea
I would verify the H.O. cams against the '08 cams just to make sure your hunting for the right part.
There is an extensive write up on another forum that confirms the 08+ cams are actually more aggressive than the HO cams.
Old Jun 24, 2020 | 11:42 AM
Monkey 13's Avatar
Monkey 13
Originally Posted by the_only_josh
The 2008-2013 4.7L V8 has the same bore and stroke but with the different piston and head design it lost 2 cubic inches of displacement. Completely worth it for all that compression we gained.
I know the 08+ are 9.8:1 compression. What is the ratio for the early 00-07 motors?
Old Jun 29, 2020 | 08:11 AM
superdak05's Avatar
superdak05
if your on facebook, check out flyin ryan performance. he will be able to get what you need and will be able to give you a great tune. frptuning.com
