which coil is p2302 code talking about?
Old Aug 4, 2020 | 10:40 AM
David Kalinowski's Avatar
David Kalinowski
Default which coil is p2302 code talking about?
I replaced my coil on cylinder 1 because it was destroyed (was also getting a code for missfire on Cyl1 thats when I discovered the dead coil), cleared codes with scan tool. Now the p2302 code is a pending fault again. I did not change the spark plug with the coil should I have done that? should I just change all the plugs? Its been a couple years maybe 3 years now since I put them in.)
Old Aug 6, 2020 | 05:41 PM
erau's Avatar
erau
2005 manual:
P2302-IGNITION COIL 1 SECONDARY
CIRCUIT- INSUFFICIENT IONIZATION
Old Aug 6, 2020 | 05:45 PM
erau's Avatar
erau
Adding to above:
P2305-IGNITION COIL 2 SECONDARY
P2308-IGNITION COIL 3 SECONDARY
P2311-IGNITION COIL 4 SECONDARY
P2314-IGNITION COIL 5 SECONDARY
P2317-IGNITION COIL 6 SECONDARY
P2320-IGNITION COIL 7 SECONDARY
P2323-IGNITION COIL 8 SECONDARY
Old Aug 6, 2020 | 08:55 PM
David Kalinowski
code finally stayed away. Thanks for the info.
Old Jul 18, 2021 | 02:11 PM
GoatKnight's Avatar
GoatKnight
What did you do to fix it? I think I am having similar problems.
Old Jul 20, 2021 | 11:14 AM
dakotaff's Avatar
dakotaff
Similar problems, or same code.
Old Aug 12, 2021 | 11:17 AM
TomRod's Avatar
TomRod
The same code, I think to change the coil and plugs. Since it often fails, my car is not new, so most likely the problem is in them, I use mas-8 or CarBole, here you can see the top coils for 5.3 vortec and how to install them, perhaps beginners will be interested.
