No crank no start 05 dakota 4.7 4x4 auto
Old Sep 21, 2020 | 11:17 AM
05Dakota$pit's Avatar
05Dakota$pit
Default No crank no start 05 dakota 4.7 4x4 auto
Bought truck off friend of mine he thought TRS was bad. I got truck for my son I put in the trans solenoid,PCM, FCM, bought and programmed new key fob and still no start off key can spray shot starting fluid and jump starter over and it fire up and runs great. I have to do that same process every time I fire it up. Any help or ideal will be appreciated
Old Sep 22, 2020 | 04:59 AM
erau's Avatar
erau
If I understand correctly, it's not cranking from the battery only, so it needs to be jumped every time? How old is the battery?
Old Sep 22, 2020 | 04:56 PM
05Dakota$pit
Battery is new it won’t start with key have to jump starter over and spray shot of starting fluid
Old Sep 22, 2020 | 09:41 PM
superdak05's Avatar
superdak05
when you try and start truck is there a little red light on dash? if so its the security system disabling the start function, pull that fuse and see if there is any luck.
Old Sep 22, 2020 | 11:19 PM
05Dakota$pit
No red light on have checked on that thought possibly it might have been that to
Old Sep 25, 2020 | 03:21 AM
djsilverjohnson's Avatar
djsilverjohnson
If it's not the security system, I'd start with the ignition switch.
Old Sep 25, 2020 | 09:15 AM
05Dakota$pit
thanks I’ll try it. I’m trying to stay away from taking it to the dealer
