PBT vs. PPX paint code
Old Mar 7, 2021 | 06:09 PM
PatriotBlueDakota's Avatar
PatriotBlueDakota
Default PBT vs. PPX paint code
I'm looking to repair a scratch on my '05 Dakota with Patriot Blue pearl coat (paint code PBT/QBTS on the build sheet). The only Patriot Blue paint pen I can find from Mopar is this one:
https://store.mopar.com/accessories/...6102967AA.html
Does anyone know if paint code PPX is the same color? Or is it going to look off?
Old Mar 8, 2021 | 03:34 PM
dakotaff's Avatar
dakotaff
I've had to use a different paint code in the past for my Inferno Red Color, PRJ is what i looked for, and PRH is what I used, and the paint was pretty much a match. I painted the rear splash guards and they looked perfect, pictured below. It may differ a little, as any batch can, but this one shows PBT if you'd rather get that one.
Old Mar 8, 2021 | 10:03 PM
PatriotBlueDakota
I ended up going with the one you linked. Thanks for the help!
Old Mar 8, 2021 | 11:14 PM
regg187's Avatar
regg187
had trouble with PBJ too Atlantic Blue. Every one I had made up looked so dark using the correct formula. in 2k urethane. finally i color sanded way more than needed but it was close enough to blend then.
Old Mar 9, 2021 | 06:23 AM
Moparite's Avatar
Moparite
https://www.paintscratch.com/cgi-bin/select-color.cgi
