Installing transmission cooling line
Old Jun 3, 2021 | 07:54 AM
dakotadadv8's Avatar
dakotadadv8
Default Installing transmission cooling line
Looking for help installing transmission cooling line for 06 Dakota V8. Tough to get the pre-bend return line into the vehicle since there is little room. Do you need to lower the front axle/differential to install the lines?
Old Jun 8, 2021 | 08:25 PM
regg187's Avatar
regg187
onmy05 v6.it was noproblem at the outlet of the radiator trans coolerIcut the line an ran a line from there into the cooler an the return line i joined back to the other piece of the the cut radiator line to go back to the trans. all work done at lower rt end of radiator
