Engine control module needed
Old Feb 11, 2022 | 09:55 AM
Northernbay01's Avatar
Northernbay01
Default Engine control module needed
Mechanic confirmed ECM is bad. Traced out & confirmed what dealer was saying. For 05 Dodge Dakota w/ 3.7 ltr v6. No longer available from Dodge
Old Feb 11, 2022 | 10:30 AM
https://carcomputerexchange.com/dodg...AaAj2oEALw_wcB
https://www.protechautosystems.com/p...AaAgunEALw_wcB
https://www.ebay.com/itm/333564269616
Just a few from a google search.
Old Mar 16, 2022 | 01:08 PM
David Kalinowski's Avatar
David Kalinowski
I've used carcomputerexchange.com and maybe it was just the one they sent me, but after putting it in the truck ran like utter slop, put the old one back in and it ran like normal (except for issue of blowing coil packs. which ended up being a short in the wireharness from the ECU to the coil and not the ECU it self) They also only refund part of your cost if you just return it (they have a
restocking / testing fee" ended up being nearly half the amount I paid.. so yea. not sure if the ones from NAPA are any better but it could be easier to deal with a local parts store.
Old Mar 17, 2022 | 06:00 PM
Tedybear315's Avatar
Tedybear315
I've used an ebay company called "All Computer Resources" via eBay in the past with very good results.
Just keep your receipts and documentation in case of a warranty.
S-
