3rd Gen, 2006 Dakota, RW ABS module VIN matching?
Old Mar 1, 2022 | 11:22 AM
Bajabob's Avatar
Bajabob
I have the Auto MaxiCheck Pro with ABS bleeder support. I believe it was a couple hundred dollars online. Pretty straight forward on the programming of the ABS module. Just plug it into the OBDII port and follow the instructions in the manual. There are also a few videos on YouTube on how to do it. All in all, it is pretty easy to replace and reprogram.
Old Mar 7, 2022 | 07:47 AM
contactsports's Avatar
contactsports
Great. I did a search on Google and it seems these units are out of stock everywhere. Does anyone know if the Foxwell NT630 is a suitable alternative? Somewhere in the $100-200 range would be great.
Thanks!
Old Apr 3, 2022 | 12:12 PM
contactsports
Bump.
Anyone have a recommendation on a scanner that will do ABS programming? Something in the $100-200 range? Must work on 3rd gen Dakota, thanks!!
Old Feb 13, 2023 | 12:17 PM
Carlitos007's Avatar
Carlitos007
Hello:
Sorry to revive this thread from the dead, but I'm experiencing the same issue with my '08 Dakota.
Did you end up purchasing the Autel Maxicheck Pro? if so, did this fix the issue with your Dakota? The scanners are readily available online, and I'm tempted to purchase one just to keep a few used ABS modules in my shelf due to the unavailability of the part as new from the dealer.
Old Mar 8, 2023 | 03:25 PM
Carlitos007
I had to buy one at a pick a part yard. Just removed the electronics module from the new unit and swapped it out on my truck. No need to disconnect the brake lines. It is located under the power block behind the battery. I then used an Autel scanner to program it to my system.No more codes and working great for a couple of years now. Unfortunately, there are no new units available for our trucks.
Bajabob: I had sent you a PM to ask you some questions about the module swap.
Thanks
Old Mar 9, 2023 | 12:01 PM
Bajabob's Avatar
Bajabob
Carlito007, I just sent you a private message. Sorry for the late response, busy life right now.
