Pesky Cylinder #7 misfire
Old Mar 9, 2022 | 09:48 AM
5476Dakota's Avatar
5476Dakota
Default Pesky Cylinder #7 misfire
I have a 2005 Dodge Dakota 4.7 V8. For sometime now this truck has had a Cylinder #7 misfire. The truck now has a new engine installed, New #7 Injector, New #7 Coil, All new NGK plugs, New EGR Valve and New PCM. But the truck still has a cylinder #7 misfire. I even swapped the intake on the truck. This is a dead miss. If you unplug the coil at idle it makes no difference on engine shake. After the engine was installed the truck still had a cylinder #7 misfire. It would gas soak the plug in a couple of miles. After the new PCM was installed and new injector the plug looks ok after driving. I just preformed a compression check to see if something was wrong with the new engine and all the cylinders are within 5 psi of each other. I never get a random misfire code just #7 misfire. No other codes even with the new PCM. I don't know of anything else that could make this truck only skip on 1 specific cylinder. Has anybody ever ran into this problem? The truck only has 71,000 miles on it and the new engine has 800 miles on it.
Old Mar 9, 2022 | 10:20 AM
Since you replaced everything else.... Time to check the wire harness for the cylinder 7 coil, and injector. Think I would start with the coil, as the injector appears to be actually working.
Moving this to Third Gen Dak section for ya.
Old Apr 9, 2022 | 02:22 PM
5476Dakota's Avatar
5476Dakota
Tried straight wiring new connector from coil to the Brown wire on the computer (bottom black harness) Red wire straight to the battery. Still has a skip on #7. I just put a new fuel pump on it and that helps with the lose of power a little bit. Inside of gas tank was clean as a pin. No dirt or anything of any kind. A new problem that it has is under heavy acceleration it falls on its face and the whole truck starts shaking. Even with new pump. But only on a steep uphill grade and heavy acceleration. Then the check engine light blinks with a door chime sound. The only code even under this condition is Misfire Cylinder #7. When it does this the power to the truck cuts in half. No power at all. It's hard to believe this is just 1 cylinder skipping. I have also put on 3 of the 4 o2 sensors. Both on the Cylinder #7 side and the downstream on the pass side. No change cylinder #7 misfire. I don't know what else it could be. Fire, fuel and compression . But still a misfire on that cylinder. I also put on brand new fuel injector pigtails (Soldered In) on the cylinder #1'3'5 and 7. I'm about $6000 in this repair with no real solution. (New Motor was caused by overheating. radiator blow out at 80 miles an hour.)But it had a skip before this happened.
Old Apr 9, 2022 | 02:28 PM
5476Dakota's Avatar
5476Dakota
The truck doesn't have a true dead miss now. It will smooth out and then quiver from time to time and the longer you sit at a red light the worse the skip gets. Checked the plug again. No gas and it doesn't look fowled.
