Hunting idle at start
Old Apr 28, 2022 | 05:15 PM
Jim_2006Dakota's Avatar
Jim_2006Dakota
Default Hunting idle at start
I've already had the map sensor replaced, and the IAC valve replaced, and my idle still hunts when first started. I used to think only when cold, now it seems even warmed up. Does anyone have any ideas? Thank you in advance for any info.
Old Apr 28, 2022 | 07:04 PM
philipat's Avatar
philipat
Have you tried cleaning the throttle body?
Old Apr 28, 2022 | 08:01 PM
Jim_2006Dakota
I did a little when I had the air tube off, just at the throttle plate. Do you think a more thorough cleaning would help?
Old Apr 29, 2022 | 04:27 AM
philipat's Avatar
philipat
As long as the plate opened and closed easily and smoothly, then it should be working fine. Beyond that, I'd have to check the service manual to see if there was something in there that might help. There's a sticky in this forum where you can download the 2005 FSM. It should be basically the same for your truck.
Old Apr 29, 2022 | 06:41 AM
Jim_2006Dakota
Thank you for the info. I will check out the manual.
Old Apr 29, 2022 | 07:28 PM
RedRam2002's Avatar
RedRam2002
I had a similar issue with my 4.7 Ram and changed the TPS - fixed it and a surging it sometimes had on the highway.
Old Apr 30, 2022 | 08:15 AM
erau's Avatar
erau
Make sure that any electrical sensors/parts you use are OEM, including the IAC. Aftermarket electrical stuff on these trucks have caused all sorts of headaches.
Old May 6, 2022 | 07:42 PM
hidden1's Avatar
hidden1
I 2nd that on the oem sensors.Especially 02 an iac,tps,map sensors .
Better to use one off another truck oem than brand new off brand.
