Random Misfire
Old Mar 9, 2023 | 10:55 AM
How is fuel pressure? What plugs did you install? What motor do you have?
Old Mar 9, 2023 | 11:29 AM
cornbread256's Avatar
cornbread256
Not sure how to check fuel pressure. NGK copper plugs. 3.7 V6 2WD 6 speed Manual Trans
Old Mar 9, 2023 | 01:02 PM
Need a gauge. Should be able to rent/borrow one from your local parts store. Should be a schrader valve on the fuel rail to screw it onto. (looks kinda like a tire valve stem.) Plugs are good.
Old May 23, 2023 | 07:12 PM
FishingWill's Avatar
FishingWill
I went through 3 crank shaft sensors and 3 cam shaft sensors none would work I even bought a new PCM turns out the fix was new Mopar sensors they linked right up no problem.
