2007 Dodge Dakota Starting issues
Old Jan 19, 2024 | 02:27 PM
WyomingCowboy's Avatar
WyomingCowboy
Default 2007 Dodge Dakota Starting issues
My sons 2007 Dakota has issues starting, he turns the key, and it tries to turn over. He will turn the key off and try to turn it over again and it starts up, we have changed the fuel pump, Fuel injectors, Spark plugs, Starter and nothing is fixing the issue....... Any help will be greatly appreciated.
Old Jan 19, 2024 | 03:50 PM
Does it just crank? Crank slow? Not crank at all?? Or does it just not fire?
Old Jan 19, 2024 | 06:06 PM
WyomingCowboy
It just cranks and like I said he turns the key completely to the off and then goes straight to start it again and it turns over.
Old Jan 19, 2024 | 10:04 PM
Try cycling the key a couple times, then starting it. Anything change?
Old Jan 20, 2024 | 01:13 AM
WyomingCowboy
This happens every time he tries to start it, no matter how many times he cycles the key
Old Jan 20, 2024 | 03:02 PM
pierrejoly's Avatar
pierrejoly
since it cranks, it needs three things to start. air, fuel and spark. Techically it needs 4 things, compression.
have you checked that you do have fuel pressure at the fuel rail? are the injectors correctly firing? are you sure you are getting spark? is the throttle body clear and moving freely? are you getting any codes? even with a few cylinders with low compression, it should still start. my old v6 started and moved under it's own power once when we had to move it while changing the spark plugs. it had 2 plugs out, 2 cylinders without the coils plugged in and only one set connected. So it should start even if only a few cylinders are working correctly, especially if the good ones are on a cylinder pair
